Application circuit of HA1392
Source: InternetPublisher:风向西瓜 Keywords: Application circuit BSP audio power amplifier bandwidth Updated: 2020/07/22
The HA1392 audio power amplifier integrated circuit produced by Japan's Hitachi Company is ideal in terms of performance indicators and appearance structure design. It has a wide voltage application range; internal thermal protection, noise suppression, OTL mid-point balance, etc.
are well designed; output It has strong load capacity, moderate frequency bandwidth and moderate power, simple peripheral circuits, and dual input and output. It
can be called a superior audio power amplifier IC. It is not only used in many famous brand radio cassette players, but also in audio
equipment During maintenance, it has become a powerful power amplifier circuit.
The interior of HA1392 is composed of the same two power amplifiers and noise suppression and other functional circuits. The input adopts a double-ended differential circuit
, and the final stage is a complementary output power amplifier. It adopts a single-in-line 12-pin plastic package. The functions of each pin are: 1 - feedback terminal,
}o human terminal, 3 - decoupling, 4 - squelch, 5 - hoop terminal, 6 - feedback terminal, 'Bu Output, 8 is bootstrap, } is ground,
10 is power supply, 11 is bootstrap, 12 is output.
The electrical characteristics of HA1392 are: power supply voltage 12V, quiescent current 36mA, voltage gain Gv=46dB, output
power 4.3W (RL=4n), harmonic distortion is set to ∞=0.25%, when BTL connection (RL=80,, Vc=20V), Po=
22Wo
- Tutorial on making a MIDI arpeggio synthesizer
- Preamplifier circuit made of composite screen triode electron tube 6C5P
- Installation of electron tube differential amplifier circuit
- Using an old tube radio to make a 6N1+6P14 tube amplifier
- Dual power supply audio power amplifier circuit using LM1875
- Audio power amplifier circuit powered by a single power supply using LM1875
- LM4903/4905 high gain audio amplifier circuit
- Improved Marantz 7-tube preamplifier circuit
- Auxiliary audio power amplifier circuit using LM4732
- Dual power supply audio power amplifier circuit composed of LM4730/LM4731
- Motor overcurrent protection circuit
- Excellent performance household inverter power supply circuit
- Self-defense anti-riot circuit
- Pulse therapy circuit
- Peanut and melon seeds roasting machine circuit
- Diode balanced amplitude modulation circuit
- Parallel crystal oscillator
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- superheterodyne radio circuit
- Various signal generator circuits
