Power amplifier using LF356
Source: InternetPublisher:三岁就很酷 Keywords: Amplifier LF356 BSP switch Updated: 2021/03/29
It is a power amplifier using LF356 as preamplifier and equipped with DC servo circuit. In line with the principle of simplicity, the circuit
uses an I_F356 to form an attenuated tone control circuit with a pass-through switch . The function of the pass-through switch
is to cut off the tone circuit when playing music with high fidelity (such as CD records), so that the amplifier outputs unmodified
sound.
For the power amplifier A1514A, remove the bootstrap circuit and connect pins 6 and 7. After canceling the bootstrapping, although the output power
is reduced by 4W, it is beneficial to reduce transient distortion and improve the sound quality.
The power amplifier is DC. By short-circuiting the inverting auxiliary terminal in the typical application circuit and adding LF356 to form a DC servo
circuit, a DC power amplifier circuit is formed.
The power amplifier stage uses a double-bridge rectifier power supply, and the pre-stage and servo circuit use independent active servo power supplies.
- 6P3P parallel 20W power amplifier experiment
- Biliary duct 2A3C Class A amplifier
- Design of a tube amplifier that uses the mains electricity to directly provide screen working power
- 18-inch large speaker
- Inverting power amplifier circuit composed of LM4732
- Dual power supply audio power amplifier circuit using LM1875
- Volume synchronization circuit constructed with discrete components
- Bridge output audio power amplifier circuit composed of LM1876
- Improved Marantz 7-tube preamplifier circuit
- LM4819 high gain audio amplifier circuit
- Electronic thermometer circuit
- Ultrasonic blind pathfinder circuit
- Electric massager circuit
- Chicken supplementary light to increase egg production rate circuit
- Agricultural small tractor lighting circuit
- Farmland drainage automatic control circuit
- Diode Balanced Mixer Circuit
- OTL low frequency power amplifier circuit
- Home appliance repair signal generator circuit
- Sine wave signal generator circuit
