Constant current sink circuit controlled by external voltage
Source: InternetPublisher:张七岁 Keywords: Constant current voltage control absorption circuit external voltage Updated: 2021/03/30
Control the voltages at the two input terminals of the OP amplifier Ai to be equal. in current.
The voltage generated across the sensing resistor Ra is,. . Ra,
compare this voltage with the control voltage EIiv, if E, IV>l. . Rs, will make d. The output potential increases,
,. Increase.
A FET in Darlington connection with the current control transistor Trz is used for elimination.
, r The error caused by the base current, which flows out from the collector through the FET.
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- A very convenient small power supply circuit to share
- Schematic diagram of car cigarette lighter to USB power port
- In-depth analysis of DC-AC converter inverter
- Recommended circuits for different power on times of LM4911
- LNK304 non-isolated LED light string driver circuit
- Charging control circuit made by solar energy
- An ultra-low output voltage regulator
- Production of backup power supply for cordless phone
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Voltage controlled sawtooth oscillatora
- Differential circuit with constant current
- Production of high-quality active two-way constant current power amplifier 01
- DC servo constant current power amplifier 01
- General circuit diagram of a simple battery automatic constant current charging circuit
- 5A constant voltage/constant current regulated power supply
- Constant current timing charger circuit diagram using NE555
- Constant current charging circuit diagram composed of LT1307
- Constant current working circuit of Hall sensor THS103A
- Constant current timing charging circuit
