Negative voltage converter to get -5 to -15V voltage from +5V power supply
Source: InternetPublisher:supremeOne Keywords: Power supply voltage converter BSP FET Updated: 2020/04/04
The internal composition of converter JC (MAX634) is shown in the circuit circle. The conversion
frequency has nothing to do with the load, and is approximately kHz (when CI= 47pF). The inductance
conversion is performed by the Pch MOS FET , and the induced voltage during disconnection
is rectified by the diode Di for negative voltage rectification, because the reference of 1.25 is used. Voltage and feedback terminal P, I
so - voli = 1.26
- Build a simple buck-boost regulator and test it on a breadboard
- Driving circuit of switching power supply field effect tube
- LED rechargeable flashlight circuit diagram
- Parallel DC regulated power supply circuit diagram
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Power supply circuit that can reduce LM317 ripple
- 3~15V 10A adjustable voltage regulated power supply
- Car power 1.5V-12V six-speed converter
- MIC4680 constant current charger
- LM317T voltage regulation adjustable circuit diagram explanation
- Motor overcurrent protection circuit
- Excellent performance household inverter power supply circuit
- Inpatient pager circuit
- Agricultural temperature control circuit
- Straw returning to field crusher circuit
- Agricultural spraying and insecticide control circuit
- DC ammeter
- Diode square rate detection circuit
- Capacitive feedback oscillator circuit
- Wireless microphone circuit
