Half-wave synchronous detection circuit composed of switching circuit
Source: InternetPublisher:同住地球村 Keywords: Switching circuit detector circuit BSP low pass Updated: 2020/12/20
An analog switch is used to alternately turn the input signal on and off, and a low-pass filter smoothes the pulsating current
(pulsation is removed and becomes DC). The OP amplifier Ai is a buffer amplifier , which is opposite to the input resistance of the low-pass filter
behind it , and the output resistance must be
very small.
If the DC blocking capacitor C is not added, the error or drift caused by the DC offset of the front stage
will affect the performance of the circuit. The selection of the capacity should ensure that
the impedance is small enough for the signal frequency. 6
OP amplifier A2 is a zero-crossing comparator, so it should be selected Ic with fast conversion speed,
otherwise phase lag will occur. When the reference input contains noise, a certain
hysteresis (positive feedback) should be added. The port signal waveform is based on a sinusoidal transition. If
the TTL level can be used, a C-MOS analog switch can be used to simplify the switching circuit composed of Trlz
- How to test whether the multimeter is working properly
- Simple and practical EPROM detection circuit
- Simple infrared detector
- Design of blood analyzer
- Transistor reverse breakdown voltage tester-----Transistor tester
- Low resistance connection tester circuit diagram sharing
- An electronic load meter using LM324 operational amplifier as the main control device
- Application of TDA1514
- PHGS-4 computer multi-channel industrial acidity meter circuit 01
- voltage amplifier circuit
- Motor forward and reverse control wiring diagram (2)
- Ultrasonic blind pathfinder circuit
- Straw returning to field crusher circuit
- Proportional frequency discriminator circuit
- Frequency modulator composed of NE566
- Diode square rate detection circuit
- Schiller oscillator circuit
- color discrimination circuit
- Three primary color display circuit
- Power phase sequence display circuit
