Production of high-performance active anti-magnetic speakers 03
Source: InternetPublisher:拿铁三分糖 Keywords: Speaker BSP potentiometer Updated: 2020/08/08
The dual-channel karaoke circuit is shown in Figure 9-60. The core component of this circuit is a professional reverberation karaoke
chip from Panasonic Corporation of Japan. The vocal signal sent from the microphone input end
is divided into : one channel is directly fed to 1VT6, and the other channel is filtered and amplified by IVT3 and then fed into the delay loop composed of lcl and 1C2. Delay processing is performed
, and then filtered and amplified by 1VT4 and 1VT5. The signal output by 1VT2 is mixed and amplified at IVT6
to output a vocal accompaniment signal with a reverberation effect; 1RP1 in Figure 9-60 is the microphone volume control potentiometer. , 1RP2 is
the reverberation depth control potentiometer.
The signal input and tone control circuit is shown in Figure 9-61. The signal input circuit is designed for two sets of high and low level inputs.
2xsl is a high-level input terminal, and 2XS2 is a low-level input terminal. In actual use, you can first try to input the signal from the high-level input terminal
. If the output power cannot meet the requirements, then try to input the signal from the low-frequency terminal. This can avoid overload signals at the speaker output terminal;
the tone control circuit is specially designed for tone control by Toshiba Corporation of Japan. It is composed of integrated circuit TAP7630P and its peripheral devices. It has
the function of single-ended DC potential to control the high and low tones, balance and volume of two channels. Since the balance potentiometer is not used in a
high amount, in order to reduce the impact of external adjustment Inconveniently, this design uses 2R10 and ZR11 balance resistors to always lock the balance control potential
in a balanced state; in Figure 9-61, 2RP1 is the volume control knob, 2RP2 is the bass control knob, and 2RP3 is the treble control
knob.
- How to measure short circuit and ground with a multimeter
- Simple and easy to make zero degree detector
- Convenient and fast power line break detection circuit
- 4040 Mobile Phone Electromagnetic Radiation Demonstration Experiment Circuit
- Digital electronic thermometer using semiconductor diode as temperature sensor
- Analysis of valid and fault conditions of differential signals
- Production of acoustic and optical digital level detector
- DS8 type 100V, 5A mutual inductance three-phase three-wire electric meter wiring
- Multimeter DC voltage measurement circuit
- Differential amplifier circuit
- Motor forward and reverse control wiring diagram (2)
- Voice controlled flash LED light circuit diagram
- Particle clogging alarm circuit of wheat seeder
- Junction field effect transistor mixer circuit
- collector amplitude modulation circuit
- Crabo oscillator circuit
- Wireless microphone circuit
- color discrimination circuit
- Three primary color display circuit
- Sine wave signal generator circuit
