Active electronic crossover power amplifier system
Source: InternetPublisher:风向双子座 Keywords: amplifier Updated: 2021/08/10
The specific circuit of this system is shown in Figure 9. The external input signal from the front stage is first sent to the buffer composed of IC A.
The signal output by 1CA is divided into two channels and sent to IC respectively]. The second-order BUTTER WORTH high- and low-pass filters composed of 1C2 and IC
3, Ic4
have their slope set at 24d B/oct and the frequency division point set at 4kHz. The divided signal is then sent to the filter
composed of 1CB Icc The buffer performs impedance transformation to match the impedance of the subsequent power amplifier .
- How to test whether the multimeter is working properly
- Temperature Range Monitoring System
- Multi-speed current test circuit of transistor HFE
- How to Simplify Analog Front-End Design for Heart Rate Monitors
- Simple and easy to make zero degree detector
- How to create a simple oscilloscope using the Basys3 board
- Low resistance connection tester circuit diagram sharing
- AC ammeter circuit
- voltage amplifier circuit
- High resistance DC differential amplifier circuit
- Tube crossover balanced inverter circuit diagram
- "Beep, beep, reverse" reminder circuit
- Analysis of self-retained feedback of OCL power amplifier
- AP500 and its application circuit (e)
- LM3886 BTL amplifier
- Power amplifier composed of LM2876
- Diamond differential input power amplifier power circuit
- Car active subwoofer
- Upper and lower symmetrical negative feedback mode field effect transistor power amplifier 02
- New Current Drive Amplifier 02
