Car active subwoofer
Source: InternetPublisher:jikai233 Keywords: Speakers BSP amplifiers Updated: 2020/05/28
The section where the speakers are fixed . Its outer diameter must be consistent with the inner diameter of the paper tube to facilitate the fixation of the speaker.
Open a wiring trough on its outer circle, fix the speaker on the wood, brush the cavity on the wood, and fix it in the center of the conduit. The speakers
use two 8t 16.5-inch bass in anti-phase parallel connection. The power amplifier adopts TDA2005M and is connected in BTI-form, as shown in Figure 9-47. This
is a circuit form that can provide larger output audio power for car power supplies. Although its output power is somewhat insufficient for a subwoofer,
in actual use, the effect is quite satisfactory. 6 When
using, place the subwoofer Under the back seat of the car, the bass signal can be picked up directly from the speaker . Be careful not to connect the wrong phase.
If this subwoofer can be equipped with a subwoofer amplifier of more than 50w and used in a home theater system, the effect will be better.
- DIY Multimeter High Frequency Signal Probe
- Make a Economical and Practical Rectifier Voltmeter
- Using NE555 to make diode and triode detector
- 5 tone detector circuit diagram
- Low resistance connection tester circuit diagram sharing
- A simple electronic muscle stimulator circuit
- Electric vehicle luminous voltmeter with undervoltage alarm
- Use LM3915 to make a practical audio power meter
- Application of TDA1514
- Numerical control following or inverting circuit
- Motor overcurrent protection circuit
- Electric massager circuit
- Egg warming circuit
- Double detuned loop frequency discriminator circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- Diode balanced amplitude modulation circuit
- Crabo oscillator circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Voltage controlled power supply second-order high-pass filter circuit
- Color display circuit
