Production of high-quality active two-way constant current power amplifier 03
Source: InternetPublisher:消失的歌 Keywords: constant current power amplifier phase shift network Updated: 2021/05/31
10. For an electronic crossover with good performance, in addition to the conventional indicators such as distortion, load, and impedance, it is also important to consider its attenuation rate. The rate increases
with the order of the crossover network . Generally speaking, the larger the attenuation rate, the better, which
can reduce the distortion caused by the mutual interference of treble and bass. However, the phase shift also increases with the order. Generally , the smaller the phase shift, the better. In summary, it is generally believed that the second-order frequency division is slightly better. Figure 9-7 shows the amplitude characteristics of
the second-order high-pass and low-pass filter networks . And the synthesized
curve mouth can be found from the figure that the synthesized curve is not a straight line, but produces a depression.
- Simple and practical EPROM detection circuit
- 4040 Mobile Phone Electromagnetic Radiation Demonstration Experiment Circuit
- Temperature Range Monitoring System
- Simple and practical motor short circuit tester
- A circuit for qualitatively testing capacitor leakage
- Using a Remote Control to Make a Crystal Oscillator Frequency Tester
- Electric vehicle luminous voltmeter with undervoltage alarm
- Fluorescent tube inverter circuit and emergency lighting circuit 02
- Typical two-stage low-pass filter circuit
- Numerical control following or inverting circuit
- Dedicated servo stabilized power supply for power amplifier
- Panasonic servo stabilized power supply (b)
- Capacitors in OCL amplifiers
- AP500 and its application circuit (e)
- Amplifiers with floating power supply
- Power amplifier using LF356
- A set of power amplifiers and speakers suitable for MPC
- Production of high-quality active two-way constant current power amplifier 03
- 20W 40-500kHz power amplifier 02
- Pre-frequency crossover power amplifier
