6.8 volt transformer power supply circuit diagram
Source: InternetPublisher:酷到被通缉 Keywords: Transformer circuit diagram power supply circuit Updated: 2020/05/07
A fairly simple power supply that can be built in an hour and a half. This program is designed for a voltage of 6.8V and a current of V300mA. Replace the zener diode D4 and the voltage can be changed, if necessary, with D3. A transistor heatsink setting and load current can be added. Diode Bridge - Any, pretty good with at least 400 volts reverse voltage . By the way, we can look back to ancient times and the diode D226B, which had a terrible popularity.
WARNING!
The program is electrically isolated from AC, so you must be very careful when assembling, installing and using it.
Parts list:
R1: 4K7
R2: 5K6
R3: 3K9
C1: 1000uF/10V
D1: KU405B
D2: KC650A
D3: D817B
D4: KC168
T1: KT940A
T2, T3: KT815
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Using Lead-acid Battery as Power Source for Walkman
- Driving circuit of switching power supply field effect tube
- Energy-saving motorcycle rectifier regulator
- Constant current LED lamp driver circuit with soft start and anti-shock
- Using CW34603 to form a circuit to change the polarity of the output power supply
- A small and easy-to-make fast charger
- A novel and practical DC low voltage stabilized power supply
- 0.7~24V continuously adjustable current limiting power supply
- Practical constant current charger-----Constant current charger
- How to design a forward switching power supply?
- Furnace door interlock switch control circuit
- Neon light circuit
- Single wire AM radio circuit
- Wand massager motor drive circuit
- Newman MP4 machine power supply circuit
- Network card power supply circuit using SC1470 control chip
- A circuit diagram of a household inverter power supply with excellent performance
- Commonly used non-sinusoidal oscillator circuits, waveforms and frequency calculation formulas - pulse wave oscillator - transformer intermittent oscillator
- RS-232 computer power supply circuit
