surround sound circuit
Source: InternetPublisher:smallembedded Keywords: Surround sound BSP Updated: 2020/06/02
The surround sound processing circuit introduced in this article uses a 2-2-4 analog surround sound system. The circuit is shown in Figure 10-18.
The following briefly describes the working principle as follows:
The signal from the left and right channel equalizer is from pLPC1891⑧ , ⑨ pin input, after internal processing,
three signals are output from ②, ⑧, ⑨ pins respectively, namely left channel composite output, right channel composite output and surround sound output. In addition, the @ and ⑥ pins are status
control interfaces. Three different output effects can be obtained by inputting different voltages to the two pins.
When sl is in the "analog" position, the @ and @ pins are connected to +5 V at the same time for the "analog stereo" effect, that is, the input channel signal
will produce an analog stereo effect.
- Homemade high quality preamplifier tone circuit
- Single-ended Class A amplifier using gallstone composite tube design
- Production of 6n3 Pushing 6p1 Single-ended Tube Amplifier
- The production of 6P14 small tube amplifier
- Using an old tube radio to make a 6N1+6P14 tube amplifier
- Typical application circuit of LM4903/4905 audio power amplifier
- Class AB2 Amplifier-McIntosh MC80
- Improved Marantz 7-tube preamplifier circuit
- LM4903/4905 differential input audio amplifier circuit
- Audio amplifier circuit of the Expo flowerpot speaker
- Electronic thermometer circuit
- Peanut and melon seeds roasting machine circuit
- Agricultural small tractor lighting circuit
- Straw returning to field crusher circuit
- Greenhouse temperature control circuit
- collector amplitude modulation circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- common emitter amplifier circuit
- High and low frequency signal generator circuit
- Digital stopwatch display circuit
