Low power bipolar stable circuit design
Source: InternetPublisher:宋元浩 Keywords: circuit design stable circuit low power Updated: 2020/07/21
Stable is on the integrated circuit KR142EN6. The IC is a bipolar regulator with an output voltage of +/-15V and a maximum load current of 200 mA. Sufficient to supply the early stages of a preamplifier or power amplifier.
Diode Bridge - Any of the KTS407 series, KTS405, KTS402
Two secondary windings of the transformer, voltage at - 16 volts each.
Parts List:
C1, C2: 1000uF/25V
C4, C5: 1000
C3, C6: 33uF/25V
D1: KTS407, KTS405, KTS402
IC 1: KR142EN6
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Driving circuit that controls LED brightness using PWM signal
- Transformerless AC-DC constant current LED driver circuit
- Simple and practical LED lamp driving circuit
- Parallel DC regulated power supply circuit diagram
- Dual forward converter schematic diagram
- Power supply circuit that can reduce LM317 ripple
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- A low-cost, high-reliability battery charger for electric vehicles
- How to Select Modular EMI Filters for AC-DC Converters
- Design of adjustable DC stabilized power supply circuit module
- Power circuit b composed of intelligent thyristor modules
- 4-phase CPU power circuit using HIP6301 and HIP6602 chips
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
- Warm current power supply circuit b
- One of the transistor stabilized current power supply circuits
- Simple dual-channel variable DC power supply circuit
- Super Class A power amplifier power circuit
- Antenna amplifier synchronous power supply circuit
- ±5V, ±12V power circuit B
