4-phase CPU power circuit using HIP6301 and HIP6602 chips
Source: InternetPublisher:赔钱虎 Keywords: CPU power circuit Updated: 2021/09/25
Shown is a 4-phase CPU power circuit using HIP6301 and HIP6602 chips . The main chip outputs 4 PWM signals with different phases
. After passing through 2 H IP 6602, it outputs 4 power supplies. The 4 power supplies are then connected to power the CPU chip, which can meet the power requirements of the CPU
chip .
- Sharing layout and tips for multi-rail power supply design
- Build a simple buck-boost regulator and test it on a breadboard
- Basic connection circuit of signal and power supply composed of ISOll3
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Miniature polarity reversal power supply using MAX1721
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Dual forward converter schematic diagram
- Voltage-current converter constructed with XTR110
- Homemade Electric Bike Fast Charger
- LM317T voltage regulation adjustable circuit diagram explanation
- Some notes on electronic design
- Structure of air conditioner horizontal air deflector drive motor and circuit
- Power circuit b composed of intelligent thyristor modules
- Connection circuit between DAC0832 and 8086CPU
- Connection of equalizer and related circuits
- Voltage stabilization control circuit in power circuit
- Output 12V-10A power supply circuit
- Typical computer motherboard CPU power supply circuit
- Voltage stabilizing circuit for CPU power supply circuit
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
