Application of TDK high-power field effect tube full-bridge components in switching power supplies and class D amplifiers 01
Source: InternetPublisher:难得正经 Keywords: High power TDK switching power supply Updated: 2020/07/01
The ultra-high-power field-effect full-bridge component with model number EA40A906 is a product of Japan's TDK and has been certified by UI No. 1 in the United States. After dissection, the principle is shown in Figure 7-17. 6 Four ultra -power
field effect tubes
with thick gold-sealed legs are installed on a precision milled chrome-plated
copper block, insulated and then placed on a mirror-plated plate with a thickness of 8mm. On the copper block, all the heat dissipation blocks add up to about t kilograms.
Other components are installed on two double-sided metal perforated epoxy boards. The input end is a refined special socket, and the output is a refined Bakelite
terminal block.
- Simple and practical EPROM detection circuit
- DIY Multimeter High Frequency Signal Probe
- Simple electric tachometer
- Transistor reverse breakdown voltage tester-----Transistor tester
- Homemade Metal Detector
- Low resistance connection tester circuit diagram sharing
- Electric vehicle luminous voltmeter with undervoltage alarm
- Production of acoustic and optical digital level detector
- Application of TDA1514
- Sample and hold circuit diagram
- How should the power supply be decoupled?
- High power IGBT high frequency inverter welding machine circuit diagram
- BTL power amplifier composed of dedicated circuits
- Super fool high power amplifier module 03
- Novel high-power multi-functional amplifier module 02
- Novel high-power multi-functional amplifier module 01
- High power operational amplifier 02
- High power operational amplifier 01
- TEA-1000 power amplification improvement example 01
- Phase angle controlled high-power dynamic power supply circuit
