High power operational amplifier 01
Source: InternetPublisher:同住地球村 Keywords: High power operational amplifier BSP output power Updated: 2021/09/03
L M12 is a high-power operational amplifier integrated circuit launched by National Semiconductor (NS) in the United States
. Its power can reach 150w at 4fl load, the distortion is only 0.ol%, and the power
bandwidth is 60kHz. When driving a reactive load, the output The power can reach 8DOW.
I.M12 has the following features: input protection ~ controlled start-up, thermal limit, over-voltage cut-off
and dynamic safety range protection port
1. M12 is a four-pin T()-3 package, as shown in Figure 5-137 display, connect the shell to - vu:,
and connect to [? ] face is gold and molybdenum to prevent thermal fatigue. The internal equivalent circuit is
shown in Figure 5-138.
1, M】2 can output considerable
power without any complicated switch design. They can also be connected in parallel or bridged to obtain greater output power . The integrated circuit
can be used in power supplies, high-voltage voltage regulators, high-performance audio amplifiers, X-instruments, plotters
, and other servo control systems. As shown in Figure 5-140,
I is recommended by NS Company . The principle of audio power amplifier installed in M12 is solid. For readers' reference.
- Using NE555 to make diode and triode detector
- Temperature-frequency conversion circuit composed of CD4046
- 4-range digital voltmeter circuit using ADD3701
- How to Use a Radio as a Metal Detector
- An electronic load meter using LM324 operational amplifier as the main control device
- Fluorescent tube inverter circuit and emergency lighting circuit 02
- Simple password electric lock
- High Performance Digitally Controlled Amplifier-Gain Divider
- voltage amplifier circuit
- Temperature voltage conversion circuit
- Motor overcurrent protection circuit
- Pulse therapy circuit
- Smoking Cessation Circuit
- Electronic anti-asthma circuit
- Physiotherapy ventilator circuit
- Fish farming thermostatic control circuit
- Agricultural small tractor lighting circuit
- Farmland drainage automatic control circuit
- Inductive feedback oscillator circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
