Super fool high power amplifier module 03
Source: InternetPublisher:zht24 Keywords: High power power amplifier OCL wiring diagram Updated: 2020/04/05
Using a D series fool amplifier integrated block. A single-channel OTL or OCL audio power amplifier can be easily organized
. Figure 3-12 is a typical application wiring diagram of single-power channel OTL output . Figure 3-13 is
a typical application wiring diagram of positive and negative power supply mono OCL and output . If you need to connect a two-channel power amplifier circuit, you need to use two fool-proof power amplifier modules. Figure 3-14 is a typical application wiring diagram
of two-channel OCL-output using positive and negative power supplies.
- New function added to MF-47D multimeter - infrared remote control detection
- Electromagnetic radiation monitor
- Digital electronic thermometer using semiconductor diode as temperature sensor
- Circuit Fault Tracker
- Using a Remote Control to Make a Crystal Oscillator Frequency Tester
- Inductive Pointer Watch Battery Tester
- How to Use a Radio as a Metal Detector
- direct coupled amplifier circuit
- 3W portable megaphone circuit
- DS8 type 100V, 5A mutual inductance three-phase three-wire electric meter wiring
- 280W power amplifier power circuit diagram
- 80Wx2 high-fidelity power amplifier
- Power amplifier composed of STK4191
- Fully symmetrical complementary CL amplifier
- Using Darlington amplifier
- Production of high-quality active two-way constant current power amplifier 03
- Application of LM3886 in home theater 01
- QSC1300 power amplifier principle and maintenance
- High-fidelity power amplifier quasi-complementary symmetry (OCL) circuit
- OCL quasi-complementary power amplifier circuit diagram
