Excellent performance portable amplifier
Source: InternetPublisher:蓝猫淘气 Keywords: Amplifier BSP integrated circuit A15 Updated: 2020/12/24
It includes two channels of microphone input and line input. The power amplifier part adopts the audio power amplifier integrated circuit TD A15
19t
introduced by Philips . This circuit has a wide operating power supply voltage range, high gain,
large output power, low distortion, and few peripheral components. Features. It also has load short circuit, open circuit, overheating and other protection functions. The excellent performance of TD A15 19
determines the superiority of the amplifier. S in the picture is the squelch control switch of the amplifier; the rectifier 1N5404 is
set up to prevent the battery from being reversely connected and burning the integrated circuit. The speaker of the amplifier is required to be no less than low to give full play to its
high power. The heat sink plate of the integrated circuit must have sufficient area to ensure that
it can work normally under any conditions. The circuit of the amplifier is very simple to make and the assembly and welding are correct. , can be used without debugging.
- Simple and easy to make zero degree detector
- Convenient and fast power line break detection circuit
- New function added to MF-47D multimeter - infrared remote control detection
- Bat sound detection circuit
- Simple electric tachometer
- Fire detector made with photodiode
- Circuit Fault Tracker
- A circuit for qualitatively testing capacitor leakage
- How to Simplify Analog Front-End Design for Heart Rate Monitors
- Three-phase three-wire active energy meter connected to three ammeters
- Motor forward and reverse control wiring diagram (2)
- Self-defense anti-riot circuit
- Electronic thermometer circuit
- Electric massager circuit
- Egg warming circuit
- Rural vegetable greenhouse lighting circuit
- Power amplifier assembled with TDA1512
- Application of TDA1514
- TDA1553Q power amplifier circuit diagram
- Tube amplifier TDA1543 DAC circuit diagram
