New Current Drive Amplifier 01
Source: InternetPublisher:常思一二 Keywords: amplifier power amplifier output current Updated: 2020/11/30
For the voltage-type amplifier shown, if the RL load is an ideal resistor, its output current is also strictly proportional to the input
voltage , and the normalized curves can completely overlap, and it can also be regarded as having no "error" or "error" "No distortion",
if the load is not an ideal resistor, but a complex load with resistance, capacitance, inductance and back electromotive force,
its impedance changes with frequency, and the frequency component of the music signal changes with time , the output current of the voltage-type power amplifier
will change with the load and deviate from the proportional relationship with the input voltage, thus producing "error" and "distortion". Therefore,
even if the voltage-type power amplifier reaches the ideal zero-distortion state, it will not Only for the output voltage,
distortion will inevitably occur for complex output currents. Figure 6-21(b) is a schematic diagram of the current mode power amplifier. For an ideal amplifier A, its output
current is only determined by the input voltage and R determines - VL/R, and has nothing to do with the load RL, so regardless of the load size,
the output current of the current-mode power amplifier is constant and has a strict proportional relationship with the input voltage, while the output voltage is related to the load impedance.
In fact, the current-voltage relationship between current-mode power amplifiers and voltage-type power amplifiers is exactly "swap". The output current of an ideal current-mode power amplifier is
zero distortion, but for complex resistive-capacitive inductive loads, its output voltage will inevitably produce distortion. We The problem faced
is very simple and clear: would we rather have current without distortion or voltage without distortion? Because the speaker is a current-driven load, and
the position of its diaphragm is determined by the current flowing through the voice coil, so we would rather have current without distortion. q
- Simple and practical motor short circuit tester
- Analysis of valid and fault conditions of differential signals
- How to Simplify Analog Front-End Design for Heart Rate Monitors
- A low-cost inductance meter consisting of a single IC
- An electronic load meter using LM324 operational amplifier as the main control device
- PHGS-4 computer multi-channel industrial acidity meter circuit 01
- DT8 type 5A current mutual induction three-phase four-wire active energy meter wiring
- AC equivalent amplifier circuit
- 3W portable megaphone circuit
- Directly coupled push-pull power amplifier circuit
- 280W power amplifier power circuit diagram
- Amplifiers with floating power supply
- Power amplifier composed of STK4191
- TDA1516BTL power amplifier
- OCL power amplifier without differential input
- High-fidelity power amplifier using switching power supply 02
- 70W integrated power amplifier
- Simple 50W high-quality power amplifier 01
- Current negative feedback amplifier
- Simple and supreme 200W fully symmetrical power amplifier
