Simple and supreme 200W fully symmetrical power amplifier
Source: InternetPublisher:拿铁三分糖 Keywords: Power amplifier BSP protection circuit Updated: 2021/08/27
In many fever articles in recent years, the supremacy of simplicity has always been a topic that many enthusiasts talk about. What is introduced below
is such a completely symmetrical power amplifier circuit with simple circuit and excellent effect.
The circuit principle is shown in Figure 3-49. o STK6004C is an ultra-high-power thick film circuit manufactured by Japan's Sanyo Company.
There are three groups of high- current totem pole output pairs inside. Each group has a withstand voltage of not less than 200V and a current of not less than 15A. , filled with
transparent silicone gel that has good thermal conductivity, has its own heat dissipation and is insulated from the internal circuit. Because the internal circuit is very complex and part of it has been solidified, this article
will transform it and take out the essential part to become the circuit in Figure 3-50. Well put it It is arranged in the rear stage (third stage) of the fully symmetrical power amplifier.
The first and second stages both use ordinary differential circuits, and resistors are used as loads at all stages. They are characterized by simple circuits, low distortion, wide
frequency response , and good sound quality. 6 Because it uses a self-installed switching power supply with multiple protections, the protection circuit of this power amplifier is particularly simple. 6 Circuit
- Homemade Metal Detector
- Level measurement circuit composed of AD737
- TC02 temperature measurement circuit
- Using NE555 to make diode and triode detector
- How to Simplify Analog Front-End Design for Heart Rate Monitors
- Design of Multi-point Temperature Measurement System Based on DS18B20
- Four logic probe circuit diagrams
- Low resistance connection tester circuit diagram sharing
- High Performance Digitally Controlled Amplifier-Gain Divider
- Phase sequence indicator circuit diagram
- Voice controlled flash LED light circuit diagram
- Electronic thermometer circuit
- Greenhouse temperature control circuit
- Poultry warming temperature control circuit
- collector amplitude modulation circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- OTL low frequency power amplifier circuit
- color discrimination circuit
- Guest arrival signal recognition circuit
- Power phase sequence display circuit
