Simple 50W high-quality power amplifier 02
Source: InternetPublisher:酷到被通缉 Keywords: Amplifier BSP Updated: 2021/07/31
The power amplifier introduced in this article uses only more than 20 component circuits (one for left and right channels), as shown in Figure 6-9. Its
voltage push (excitation) part is composed of the integrated circuit FtPC 1225H and a small number of peripheral components. The final power amplifier pairing tubes
VTZ and VT3 are current amplification outputs. The internal structure of tuPC1225H is shown in Figure 6-10. The main electrical parameters are shown in the table 6-1 Institute
No. The main features are as follows:
(1) The internal circuit functions of VPC1255H are well set up, and it has the advantages of simple circuit, low cost, easy installation and adjustment, reliability and safety
(2) The circuit frequency band is extremely wide, f≥900kHz (±3dB) 6
(3) High conversion rate, SR≥15V/ys o
(4) Distortion ≤0.002", f-lkHz, Ri. -8n, Ui, - 14Vo
(5) The power supply does not need voltage stabilization.
(6) The output voltage is high and the excitation capacity is large.
- Make a Economical and Practical Rectifier Voltmeter
- Simple electric tachometer
- NE555 makes a simple and practical acupoint detector
- Simple infrared detector
- Using a Remote Control to Make a Crystal Oscillator Frequency Tester
- Homemade Metal Detector
- 1.5V and 9V battery tester circuit diagram
- AC ammeter circuit
- Geiger counter circuit diagram
- Numerical control following or inverting circuit
- Self-defense anti-riot circuit
- Smoking Cessation Circuit
- High-efficiency speaker circuit for rural stage
- Soil water shortage prompt circuit
- Domestic KD8041 integrated phase locked loop
- Mixer built with analog multipliers
- Junction field effect transistor mixer circuit
- Audio function generator composed of ICL8038
- Schiller oscillator circuit
- Double gate field effect transistor high frequency amplifier circuit
