Broadband AC isolation amplifier with frequency band 600kHz
Source: InternetPublisher:桂花蒸 Keywords: Broadband frequency band isolation amplifier Updated: 2021/09/18
This is a simple isolation amplifier composed of a high-speed optocoupler and a transistor circuit
. It cannot carry out DC (direct current) transmission. It is suitable for DC signal
isolation. It has good frequency characteristics and the frequency is 600 kHz:_3dBo
·Circuit operation Principle:
In order to make the optocoupler work under no modulation conditions, a DC value must be applied
. The function of the transistor Tfl is to provide a DC bias current for the LED. A silicon diode is connected between the base and ground
to improve the temperature characteristics.
Use of rate circuit The optocoupler is 6N136. The output current of the photodiode
is relatively small, so a body tube is used to amplify the current. In order to improve the frequency characteristics
, the base ground circuit composed of Tr earth converts the electricity/to the voltage
of the port circuit. The voltage gain is determined by the electrode resistance of Tra. In order to make
^ = odB, a 1.8kQ resistor is used. The adjustment of the operating point is completed by the transmitting and receiving
resistor . When determining the bias, the linearity of the maximum input signal should be ensured. Best
(low distortion rate).
- Homemade Metal Detector
- Multi-speed current test circuit of transistor HFE
- AC ammeter circuit
- Light Detection 4 to 20mA Current Transmitter Circuit
- Directly coupled push-pull power amplifier circuit
- voltage amplifier circuit
- Three-phase three-wire active energy meter connected to three ammeters
- Numerical control following or inverting circuit
- A simple no-load self-stop circuit for welding machines
- Differential amplifier circuit
- Broadband high frequency power amplifier circuit
- Bus door status detection circuit
- Broadband AC isolation amplifier with frequency band 600kHz
- Wideband ALC amplifier with 50MHz-3dB wideband, 20dB compression characteristics
- Computer power detection circuit
- Positive peak detection circuit
- Broadband hysteresis multivibrator circuit diagram
- Broadband low frequency frequency multiplier circuit diagram
- Broadband infrared sound transmission system
- With 50OHM input and output impedance, 16DB wideband video amplifier circuit
