Current negative feedback DC power amplifier
Source: InternetPublisher:spectrum Keywords: Amplifier BSP Updated: 2020/12/17
9. The circuit of this power amplifier is relatively simple, but its special feature is that its input stage is not a traditional differential circuit, but a new type of current
negative feedback circuit. Its advantages include wide frequency band, high conversion rate, no phase difference, etc. The Japanese Golden Throat amplifier
worth tens of thousands of dollars
also uses this kind of circuit.
During design, the input stage static voltage is set at
about 1. SmA, and the cheaper A992/C1845 is used.
A872/C1775 can also be used for the second stage, A1145/
C2705, or A1360/C3423.
D669/B649 is used for the push stage, and C5171/A1930 is better.
B649 is used for the bias tube, which is the two adjustable
resistors All use multi-turn precision adjustable resistors. The two Sw resistors at the output end
use metallized ceramic resistors, the other resistors
use 1/4W five-color ring metal film resistors, the 470VF capacitor
uses ELNA, the 0.1VF capacitor uses WIMA, and the 10VF capacitor
uses Sanyo OS-CON solid capacitors. The two diodes in the circuit
can improve the sound quality at large dynamics, which is simple
but effective. The power transformer should be a 200W toroidal transformer
, and the dual 36 Vb bridge stack should be 20A or above.
It is recommended that the filter capacitor be El.NA.PHILPS, Rubycon
and other famous brand capacitors. The impact on the sound quality is very obvious.
- Simple and convenient remote control receiver dual purpose detector
- Balcony intelligent invisible anti-theft net
- 4040 Mobile Phone Electromagnetic Radiation Demonstration Experiment Circuit
- Temperature Range Monitoring System
- A highly sensitive human proximity detector
- System display circuit of electric bicycle speed and odometer composed of CD4076 and 74LS138
- NE555 makes a simple and practical acupoint detector
- Digital strain gauge circuit using MAX1492/MAX1494
- Temperature-frequency conversion circuit composed of CD4046
- Differential amplifier circuit
- Self-defense anti-riot circuit
- Smoking Cessation Circuit
- High-efficiency speaker circuit for rural stage
- Soil water shortage prompt circuit
- Domestic KD8041 integrated phase locked loop
- Mixer built with analog multipliers
- Junction field effect transistor mixer circuit
- Audio function generator composed of ICL8038
- Schiller oscillator circuit
- Double gate field effect transistor high frequency amplifier circuit
