Fully complementary power amplifier
Source: InternetPublisher:国民男神经 Keywords: power amplifier collector emitter Updated: 2020/05/07
It consists of a two-stage voltage amplifier and a slow complementary current amplifier 6 VTl, VT2.
The first stage differential amplifier uses a constant current diode VDH1 to replace the traditional emitter resistor, which greatly improves
the stability of the ocl-circuit. The input signal
is coupled to the base of VT1 through Cl, Rl is the DC bias resistor of VT1, and C2 is used to filter out
high-frequency interference in the input signal. The feedback signal is fed back to the VT2 base by the R3 R4 and C3 network. The first-stage amplified signal is output from
the collector of VTi and is directly coupled to the base of VT3. R5 is the emitter load resistor of VT3, and the constant current diode VDHZ is the collector
load
of VT3 . Due to the constant current effect of VDH2, the amplifier excitation stage does not need to use a common bootstrap circuit, thus
overcoming the disadvantages of transient characteristics degradation caused by bootstrapping and achieving higher fidelity. VT5. VT6 is a complementary emitter power output device, and
C4 is a Miller anti-vibration capacitor.
- Simple and convenient remote control receiver dual purpose detector
- Electromagnetic radiation monitor
- Homemade Metal Detector
- How to Simplify Analog Front-End Design for Heart Rate Monitors
- 4-range digital voltmeter circuit using ADD3701
- Fluorescent tube inverter circuit and emergency lighting circuit 02
- 3W portable megaphone circuit
- Temperature voltage conversion circuit
- Numerical control following or inverting circuit
- A simple no-load self-stop circuit for welding machines
- TDA7245 power amplifier circuit diagram
- TDA2008 power amplifier circuit diagram
- TDA1701 power amplifier circuit diagram
- TDA1551Q power amplifier circuit diagram
- TDA2005 power amplifier circuit diagram
- TA7769P power amplifier circuit diagram
- TA7688P power amplifier circuit diagram
- TA7241AP power amplifier circuit diagram
- TA722P power amplifier circuit diagram
- STK460 power amplifier circuit diagram
