Circuit diagram of adjustable sine/square wave oscillator
Source: InternetPublisher:国民男神经 Keywords: Sine wave square wave oscillator Updated: 2024/02/02
The following scheme diagrams are circuit diagrams for simple and easy to tune/adjustable sine wave and square wave oscillators. Using this circuit you can easily generate sine/square waves with adjustable frequency and amplitude.
This circuit uses general-purpose operational amplifier (op-amp) IC LM101A and high-speed voltage comparator IC LM111.
This circuit provides sine and square waves with frequencies below 20Hz to above 20KHz. The nice thing about this circuit diagram is that you can adjust the output frequency by changing the variable resistor of R3. You can also adjust the amplitude of the output sine wave/square wave by adjusting the potentiometer R6.
How to define the frequency value of the output line is provided in the scheme diagram above.
- An example of LC oscillation circuit
- A simple and easy-to-make rechargeable hypnotist
- Multivibrator circuit experiment based on 4069
- 12kHz signal generator
- Variable LC Oscillator Circuit
- Sawtooth wave oscillator composed of integrating circuit and comparator
- RC bridge oscillator and its equivalent circuit
- 20~20000Hz low distortion audio oscillation circuit
- CNC pulse width circuit
- 48MHz HCMOS oscillator circuit
- Sine wave to square wave conversion circuit
- 8-bit bipolar DA converter that generates sine waves
- Sine wave-rectangular wave oscillator circuit diagram
- Triangular wave-sine wave conversion circuit diagram
- 20HZ-20KHZ sine wave-square wave generator circuit diagram
- Circuit that converts sine wave to square wave
- Voltage frequency converter circuit diagram for sine wave input
- Phase locked loop converts square wave to sine wave circuit diagram
- Triangular wave-sine wave converter circuit diagram
- Broadband square wave oscillator circuit diagram with 50% duty cycle
