Sine wave to square wave converter circuit diagram analysis
Source: InternetPublisher:国民男神经 Keywords: Sine wave generator square wave converter Updated: 2024/02/02
This sine wave to square wave converter circuit promises to provide a nice square wave, changing the sine wave delivered from the existing generator. Its main feature is that it does not require a power supply: in this way it can be simply connected between the sine wave generator and the device under test.
The input sine wave maintains the voltage multiplier formed by C1, C2, D1 and D2 to power the IC. IC1A amplifies the input sine wave and the other inverters included in IC1 square the signal and provide an output square wave with equal mark/space ratio and good rise and fall times throughout the 20Hz-20KHz range.
Sine Wave to Square Wave Converter Circuit Notes:
Minimum sine wave input amplitude required for good performance: 750mV RMS.
Best performance is obtained with input sine wave amplitudes starting at 1V RMS.
The output square wave amplitude is proportional to the input amplitude.
Output square wave amplitude for 1V RMS input: 3V peak-to-peak, with R2 set to maximum.
Minimum output square wave amplitude: 2V peak-to-peak, with R2 set to maximum.
Replacing the two silicon diodes with germanium types (such as AA118, AA119) can lower the minimum input threshold.
- A crystal-controlled local oscillator circuit diagram
- LM324 op amp makes a step wave generator
- Basic connection circuit of HA-5320 in the same phase unity gain mode
- Frequency Detection and Signal Generator Made with LM567
- A 1Hz clock generator circuit with COB
- Analog-to-digital converter application circuit design analysis
- Inexpensive high-precision digital clock time base circuit
- Switched harmonic crystal oscillator
- Sine wave square wave-triangular wave oscillator using frequency shift keying method
- Accurate reference clock oscillator circuit
- Simple audio sine wave generator circuit diagram
- Bi-phase output sine wave generator circuit diagram
- Triangular wave-sine wave generator circuit diagram
- Sine wave generator circuit diagram composed of 555 circuit
- 555 multivibrator circuit diagram
- Single pulse generator circuit diagram
- Easy to make negative ion generator circuit
- TDA0161 metal detector circuit diagram
