Quasi-Class A HI-FI amplifier with excellent performance
Source: InternetPublisher:国民男神经 Keywords: Amplifier HI-FI ST Updated: 2020/06/30
STK 3048 and: STK 615 3 are thick film integrated circuits with better performance. It is easy to make a power amplifier with superior
performance using it, but its shortcomings cannot be ignored. First of all, STK6153 is a collector output circuit, so the output resistance
is relatively large; secondly, because its internal bias circuit is fixed, its quiescent current cannot be adjusted, which is a bit regretful.
This article has not included it. After some modifications, a set of quasi-Class A HJ-FJ amplifiers with excellent performance was produced. The circuit principle
is shown in Figure 3-43. D
This machine has no special requirements for components, but it is best to use CBB capacitors (such as Xindak) for coupling capacitors. VD1 and VD2 can be used.
Light-emitting diodes with a voltage drop of 2V, RlZ and R13 can be used. 2~sw carburized resistor for power amplifier. It is worth mentioning that it uses
base current bias and makes some changes to the traditional connection method of ST K6153, changing it to a circuit with emitter output. The production and debugging of the rate circuit
is relatively simple. You only need to slightly adjust VR1 and VRZ. The final quiescent
current can be adjusted according to different personal preferences. Generally, it is appropriate to adjust it to 100mA, and then replace it with two fixed resistors . But lastly, measure the midpoint potential.
It should generally be below ImV. If it is not too messy during production, you can also directly modify it on the original circuit board, but it is best to
design printed board, which not only resists interference but also has good protection against interference. benefits and will be more beautiful.
- How to measure short circuit and ground with a multimeter
- Make a Simple Darkness Detector Circuit
- Simple and convenient remote control receiver dual purpose detector
- Detection of Bidirectional Trigger Diode
- Making an Induction Electroscope Using CD4069
- 1.5V and 9V battery tester circuit diagram
- Low resistance connection tester circuit diagram sharing
- High Performance Digitally Controlled Amplifier-Gain Divider
- High-speed gain programmable amplifier circuit
- A simple no-load self-stop circuit for welding machines
- TDA2030 14W Hi-Fi audio amplifier circuit diagram
- STK435-105 STK436 power amplifier circuit diagram
- 50Wx2 Hi-Fi amplifier
- STK4046, 4048 typical application circuit
- Typical applications of STK4101
- High quality and low price 100Wx2 power amplifier circuit
- Practical circuit 02 using STK3048 and STK6153
- 50W power amplifier 01
- Homemade high-fidelity fever HI-FI amplifier 05
- Homemade high-fidelity fever HI-FI amplifier 02
