Broadband buffer amplifier capable of driving 50Ω loads
Source: InternetPublisher:桂花蒸 Keywords: Broadband buffer amplifier BSP Updated: 2020/07/30
Since the emitter output device Tfi and the output transistor Tr. of the auxiliary stage are interconnected
, the fluctuation of the output DC level caused by P zri can be reduced.
The offset adjustment between the output 1 inputs is done by VRi .
. Use the inverting output of the collector pole of 5ffrI to change the current of the current Miller
circuit composed of Trl and Tf4 , and use Tf. and Tr4 for push-pull output.
Due to the use of two-stage amplification, there will be a time lag during conversion.
In order to increase the conversion speed, the pulse peaking capacitor
Cl (several hundred picos) should be connected in parallel to the amplifier and adjusted during installation until the square Reluctant to leave
- Simple and easy to make zero degree detector
- Simple and practical EPROM detection circuit
- Balcony intelligent invisible anti-theft net
- 4040 Mobile Phone Electromagnetic Radiation Demonstration Experiment Circuit
- DIY Multimeter High Frequency Signal Probe
- Simple electric tachometer
- Using NE555 to make diode and triode detector
- PHGS-4 computer multi-channel industrial acidity meter circuit 01
- High Performance Digitally Controlled Amplifier-Gain Divider
- Multimeter DC voltage measurement circuit
- Self-defense anti-riot circuit
- Inpatient pager circuit
- soil content measurement circuit
- Particle clogging alarm circuit of wheat seeder
- Poultry warming temperature control circuit
- Diode square rate detection circuit
- Broadband high frequency power amplifier circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- color discrimination circuit
- Home appliance repair signal generator circuit
