High-speed preamplifier for measurement that reduces noise with dual transistors
Source: InternetPublisher:常思一二 Keywords: low noise preamplifier transistor BSP Updated: 2020/08/22
The difference between the Bong circuit and the ordinary differential amplifier circuit is that it has a
voltage-current conversion circuit composed of rPl, using R. and Rlo
divide the voltage enclosed by the OP amplifier, and then convert it into current for feedback. The voltage gain of this circuit can
be calculated
according to the type A! + VRi) × (1, - Rioj_R.)
- - Rs .
If four'+v crown. It is about cricket oQ, according to ugly s=33<2~'§3kC!.
The magnification factor 4 can be in the range of l-l000.
Because the base of the dual transistor Fr is connected to -, it is
trusted by the 3.9V Qi Na diode, so the common mode input voltage will be reduced, and
the characteristics of the OP amplifier cannot be used, so attention should be paid to it. VRs
is connected in series with the collector resistors Ri and Rz of the differential amplification transistor to perform offset adjustment. If there is
a zero-point drift
in the back end of the circuit , VRZo may not be used.
If the amplification factor is reduced in a multi-stage amplification circuit, oscillation will inevitably occur
. terminal, so a phase compensation circuit (i,, and,.) needs to be added. The component parameters
are determined by the minimum gain.
- Detection of Bidirectional Trigger Diode
- Homemade Metal Detector
- Simple electric tachometer
- Fire detector made with photodiode
- Inductive Pointer Watch Battery Tester
- How to Use a Radio as a Metal Detector
- Four logic probe circuit diagrams
- voltage amplifier circuit
- High resistance DC differential amplifier circuit
- Differential amplifier circuit
- Set timing circuit when power is on
- Excellent performance household inverter power supply circuit
- Electronic thermometer circuit
- Rice mill circuit
- Farmland irrigation automatic control circuit a
- Varactor Diode Frequency Modulator
- Integrated synchronous detector composed of analog multiplier MC1596
- Crabo oscillator circuit
- High and low frequency signal generator circuit
- Three primary color display circuit
