A basic differential amplifier using only one OP amplifier
Source: InternetPublisher:ohahaha Keywords: Differential Amplifier BSP Potential Updated: 2021/12/19
The figure shows a resistive bridge circuit driven by a unipolar current . We
use this as an example to illustrate the operation of the differential amplifier circuit. When balanced input, el and e▲ are equal
, each is E/20. ez is divided by Rz and Zhan' and then added to the non-inverting input port.
Because when the OP amplifier works in the linear range, the box phase input terminal and the non-
inverting input terminal have the same potential . , so e. _厯 Chou, the output voltage eo after dividing by Ra and Ra should
be equal to zero.
- Homemade simple magnetic material tester
- Isolated 4-20mA instrument loop (RTD) circuit composed of RCV420
- NE555 makes a simple and practical acupoint detector
- Simple infrared detector
- PHGS-4 computer multi-channel industrial acidity meter circuit 01
- AC ammeter circuit
- DT8 type 5A current mutual induction three-phase four-wire active energy meter wiring
- High resistance DC differential amplifier circuit
- Phase sequence indicator circuit diagram
- A simple no-load self-stop circuit for welding machines
- electromagnetic field sensor
- Analysis of rectifier circuit types and principles
- Self-defense anti-riot circuit
- Bone hyperplasia treatment circuit
- Smoking Cessation Circuit
- Peanut and melon seeds roasting machine circuit
- Rice mill circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Wireless microphone circuit
- High and low frequency signal generator circuit
