Discrete components high input impedance preamplifier
Source: InternetPublisher:jikai233 Keywords: Discrete components preamplifier high input impedance BSP Updated: 2021/10/09
The main circuit is composed of Trl~Tr. It is a three-level direct coupling circuit
, eliminating the need for decoupling capacitors. In the bias current circuit, in order to enable Tr3 to
work at tOOJ1A, a resistor 4z is added to the source. Due to the influence of the deviation of the FET
, the resistor must be adjusted so that the emitter voltage of Tr3 is 5-5.
The bias current of Mo V, Tr2 and Yu rG is 1mA.
The gain of the circuit depends on the "1+ (chu./a) port, which is about 10 times
(20dB). R4 can be changed according to the purpose. If Ri is reduced to reduce the gain
, the load of the emitter output device Trs will be reduced. is small, so the output signal curve
will also decrease.
- How to Measure Turbidity of Liquids Using Arduino
- Simple and convenient remote control receiver dual purpose detector
- Electromagnetic radiation monitor
- Simple electric tachometer
- Isolated 4-20mA instrument loop (RTD) circuit composed of RCV420
- Using a Remote Control to Make a Crystal Oscillator Frequency Tester
- Design of Multi-point Temperature Measurement System Based on DS18B20
- 5 tone detector circuit diagram
- Production of acoustic and optical digital level detector
- High current, high power amplifier circuit
- Analysis of rectifier circuit types and principles
- Self-defense anti-riot circuit
- Agricultural spraying and insecticide control circuit
- Poultry warming temperature control circuit
- Farmland drainage automatic control circuit
- Diode balanced amplitude modulation circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- common emitter amplifier circuit
- color discrimination circuit
- Various signal generator circuits
