Anti-oversaturation function deletion circuit schematic with desaturation protection
Source: InternetPublisher:小胖友 Keywords: Circuit schematics diodes transistors Updated: 2021/12/19
A connection diagram is given to delete the anti-oversaturation network fork and retain the desaturation protection function
. In the figure , the diode VD is connected in series with two diodes VD, and VD,.
The current produced by the UAA4002 is determined by the resistor R, and the collector-emitter voltage is still monitored, although
the UAA4002 pin ve. The voltage difference between the terminal and the collector of the driven transistor is equal to the voltage threshold of
the three diodes , but since the driven transistor works in an oversaturated state
, this will not cause the problem that the driven transistor cannot be protected after desaturation+
- How to use a microcontroller to control a servo motor?
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Build a Smart Garage Door Opener Using a Raspberry Pi
- What are the challenges in designing a permanent magnet linear generator?
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Methods for Eliminating Noise of Brushed DC Motors
- PIC microcontroller controlled remote anti-theft alarm circuit
- Motorcycle anti-theft device circuit design
- A novel and practical power line anti-theft and cutting alarm circuit
- Precious home appliance anti-theft alarm
- Power diode analysis
- How to judge whether the thyristor is good or bad by triggering circuit
- Photodiode isolation amplifier circuit diagram composed of ISO212P
- Bridge connection of two power op amps
- Circuit diagram for driving LED with logic signal levels
- Ultrasonic ranging circuit
- Photoelectric detection circuit
- Internal structure of MC1411 series Darlington current driver d
- Internal structure of MC1411 series Darlington current drivera
- Diode, resistance and capacitance spark elimination circuitb
