Application of TCA785 in temperature control system
Source: InternetPublisher:子丑寅卯 Keywords: Temperature control system TCA785 BSP trigger Updated: 2021/08/25
Typical Application Examples Due to the excellent performance of TCA785, it
can be easily used in main circuits with a single thyristor or transistor, single-phase half-controlled bridge, fully
controlled bridge, three-phase half-controlled bridge, fully controlled bridge and other main circuit types.
Trigger thyristors or transistors in power electronic equipment to achieve
the purposes of temperature control, voltage regulation, DC speed regulation, AC speed regulation, DC power transmission, etc. required by users . Due to space limitations, this article only gives a few examples to illustrate
its applications.
(1) Used in temperature control systems. Temperature control is widely used in the field of power electronics technology
, such as diffusion and sintering in the manufacturing process of power electronic devices such as thyristors and transistors
; thermal fatigue and high temperature blocking tests for thyristor factory life testing, etc., all
require accurate Temperature control, Figure 12-8 shows the detailed circuit diagram
of TCA785 used to trigger the bidirectional thyristor to control temperature in this type of system
. In the figure,
the Q and Q pulses
output by TCA785 are used
to directly control the temperature in
the positive and negative half cycles of the AC power supply. Triggering the thyristor,
the phase-shifted control voltage Vl comes from
the output
of the temperature regulator TA . The TCA785 's own
working power supply is directly
obtained by the grid voltage half-transition rectification filtering and voltage stabilization by the voltage regulator tube. This structure eliminates
the need for conventional The control transformer simplifies the entire circuit, and the temperature feedback
is obtained using a temperature sensor, so this temperature control system has higher temperature control accuracy.
- Analysis of the working principle of car garage door lights
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- Design of an autonomous plant watering system using ATtiny85
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- An automated model railroad layout project using a microcontroller
- Motor automatic cycle control circuit
- Design and production of radio remote control fan stepless speed regulator
- Design and production of wireless multi-location control switch circuit
- An experimental model of an infrared radio alarm
- Motorcycle anti-theft device circuit design
- Voice controlled flash LED light circuit diagram
- Self-defense anti-riot circuit
- Homemade disinfectant circuit
- Chicken supplementary light to increase egg production rate circuit
- Farmland drainage automatic control circuit
- AC voltmeter
- Audio function generator composed of ICL8038
- Wien bridge oscillator circuit
- Double gate field effect transistor high frequency amplifier circuit
- Guest arrival signal recognition circuit
