Soft start and soft stop open loop control of lights or inductive loads
Source: InternetPublisher:elleny Keywords: Open loop control BSP Updated: 2021/03/14
Foreign high-end drum-type washing machines are driven by single-phase AC commutator motors
. Figure 7-2 typical application diagram is an example of this. This kind of washing machine requires four
speeds : washing (w), shaking clothes (D), first dehydration (spinl) and second dehydration
(spin2). In this example, the four speeds are expressed as the command speed voltage v5 of pin 5, and
their values are
Vw=0.7V
VD=1.13V
y. . . 1=5 0v
V, p1.2 =11V
is used to control the fourth speed, and there are four switches S. , S2n. S3¨ .S. . Table 7 2 shows the status of the four switches at different speeds and
the set voltage y
for pins 5 and 6 of TDA1085 .
and V, requirements. Kl.6 in the table represents the
ratio of the speed of dispersing clothes to the speed of washing (expressed as a voltage ratio), that is, K=VD/Vn.
- Servo motor pin diagram/working principle/application
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- Design of an autonomous plant watering system using ATtiny85
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- Perform surgery on the speaker protection circuit
- Motor automatic cycle control circuit
- IGBT modules block overcurrent by controlling the gate
- Design and production of no-load automatic power-off device for household power supply
- An experimental model of an infrared radio alarm
- Water supply reminder after water outage
- Ultrasonic blind pathfinder circuit
- Smoking Cessation Circuit
- Agricultural temperature control circuit
- Frequency modulator composed of NE566
- ring amplitude modulation circuit
- Diode balanced amplitude modulation circuit
- Schiller oscillator circuit
- Inductive feedback oscillator circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Color display circuit
