Connection between SLE4520 and SABA8051
Source: InternetPublisher:石榴姐 Keywords: BSP latch microprocessor Updated: 2021/11/21
This chip was launched by Siemens of Germany in 1986 and is specially used for the control
of three-phase VVVF power supply . It uses ACMOS technology and adopts a standard 28-pin
dual in-line package. This chip must be used in conjunction with an 8-bit microprocessor to generate a three
-phase SPWM drive signal. SLE4520 can convert an 8-bit number sent by the microprocessor
into a pulse of corresponding width.
Figure 6 6 shows a connection between SLE4520 and SAB8051 microprocessor,
for which Siemens has developed corresponding software. Of course,
integration with other hardware and software is also possible.
1. The internal unit of SLE4520, SLE4520, integrates a crystal oscillator t
as the oscillation source of the programmable frequency divider. It is also output to the outside of the chip through a buffer
. There is no need to connect a capacitor to the end of the crystal oscillator.
The data from the SAB8051 microprocessor
is transmitted from the PO port to the SLE4520 through ALE and WRej control, and is latched in three (phase) 8-bit latches , two 4-bit
latches, and a 3-bit address latch decoder. middle. The SAB8051 microprocessor uses the
instruction MOVX @RO, A to transmit data, in which the external address has been stored
in the register RO, and the data to be transmitted is in the accumulator A. The address distribution of each latch is as follows:
Address latch
OOH A-phase 8-bit latch
OIH B-phase 8-bit latch
OZH C-phase 8-bit latch
03H Delay time control latch
04H Frequency divider control lock Registers
The last two of the five latches mentioned above can only be written to during initialization. When the microprocessor outputs
, the 3-bit address is latched and decoded on the falling edge of the ALE signal} and
the data is loaded into the latch through the bus on the rising edge of the WR signal .
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Car ice warning circuit sharing
- How can we make the robot move precisely on a predefined path?
- What is a RADAX motor?
- Perform surgery on the speaker protection circuit
- Hydraulic control circuit design and analysis
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- A novel and practical power line anti-theft and cutting alarm circuit
- Water supply reminder after water outage
- Simple disconnection burglar alarm
- Physiotherapy ventilator circuit
- Poultry warming temperature control circuit
- Biogas concentration detection line
- Proportional frequency discriminator circuit
- Diode square rate detection circuit
- Wien bridge oscillator circuit
- Crabo oscillator circuit
- Inductive feedback oscillator circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- superheterodyne radio circuit
