M51728 DC motor speed phase-locked controller - typical application circuit
Source: InternetPublisher:蓝猫淘气 Keywords: Controller DC motor application circuit BSP Updated: 2021/06/15
M51728 is a DC motor precision speed control
phase-locked loop (PLL) integrated circuit produced by Mitsubishi Electric Corporation of Japan. The frequency of the oscillator built into the chip is compared with the frequency of the external tachometer
in the phase comparator, and a pulse signal with appropriate pulse width is output, which is fed to the DC motor
after external amplification and correction to maintain a constant speed.
There are two packaging methods. M51728L is an 8-pin single-in-line plastic package; M51728FP
is an 8-pin dual-in-line plastic package.
The power supply (pin 2) is
obtained from the external DC power supply Vs through the step-down resistor Rs and the filter capacitor Ce. Vs=9-18V, 13V is recommended. There is a voltage stabilizing diode inside to make
the voltage at pin 2 Vcc-6 9V (typical value). Due to the internal voltage adjustment of the chip,
the voltage Vs.h output at pin 4 is 27V (typical value).
- Analysis of the working principle of the sound and light controlled delay switch circuit
- Analysis of the working principle of car garage door lights
- How to remotely control devices using ESP8266 and LPC2148
- Build a Smart Garage Door Opener Using a Raspberry Pi
- Motor control circuit for starting and running without phase loss
- Design and principle analysis of practical electric curtain remote control device
- IGBT modules block overcurrent by controlling the gate
- Do-it-yourself trial production of phase failure protection device
- Precious home appliance anti-theft alarm
- "Watchdog" anti-theft alarm circuit
- Voice controlled flash LED light circuit diagram
- High-efficiency speaker circuit for rural stage
- Straw returning to field crusher circuit
- Egg heating control circuit
- Double detuned loop frequency discriminator circuit
- base amplitude modulation circuit
- ring amplitude modulation circuit
- Wien bridge oscillator circuit
- Voltage controlled power supply second-order high-pass filter circuit
- Sawtooth wave generator circuit (2)
