UC3625 brushless DC motor open loop speed control
Source: InternetPublisher:狂妄火龙果 Keywords: Brushless DC motor MOSFET Updated: 2021/05/07
28 is the drive circuit diagram of the 45V/8A brushless DC motor
. It is a voltage- type open-circuit control. An external adjustable potentiometer is connected to pin 1 to adjust the PWM duty cycle and control the average voltage
supplied to the motor to adjust the speed. The figure shows only
one side of the three-phase bridge, with pins 16 (PUC) and 12 (PDC) driving
P-channel and N-channel MOSFETs respectively . By removing the two current detection resistors RT and H,
the circuit can operate in four-quadrant mode, perform braking control , and obtain average current control
- Design and selection of electric control valve system drive
- Design of an autonomous plant watering system using ATtiny85
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- What is a RADAX motor?
- A small improvement on the ordinary refrigerator motor starting circuit
- Squirrel cage asynchronous motor reverse braking control circuit
- Design and analysis of the principle of automatic power-off switch during power outage
- An experimental model of an infrared radio alarm
- Infrared blocking alarm device
- Delay switch made with LM431
- Micro remote control receiving and control circuit
- Photocell amplification control circuit
- Stapler control circuit
- PLC chain alarm control circuit used in production process
- Detection and control circuit of electromagnetic stove
- Humidity detection box control circuit in greenhouse
- Water dispenser (Aucma) temperature detection control circuit
- Temperature measurement and control circuit
- UC3625 brushless DC motor open loop speed control
- SI9114 uses MOSFET circuit diagram
