Power amplifier circuit with bass boost compensation
Source: InternetPublisher:三岁就很酷 Keywords: amplifier circuit audio speaker Updated: 2020/10/20
It is a practical power amplifier circuit with bass boost compensation. According to the component parameters marked on the power amplifier circuit
, when the switches Sl and S2 are both open, the power amplifier can increase the output gain of
the 45Hz subcanthus audio
relative to 200Hz. The audio is increased by 7 to 8dB; sl
is closed and sz is open. When, this power amplifier can increase
the output gain of audio frequency below 30Hz relative to 150Hz and above
. . [|, the audio frequency is increased by 5~6dB; when switch S2 is in the closed state, the amplifier
has a flat frequency response of
20Hz~ 140Hz. It is obvious
that the first two output modes are suitable for driving
the woofer unit to 6+5 inches. and lo-inch foam
side speakers , while the final flat output
mode is suitable for signal detection. Actual listening shows that after using the corresponding bass boost compensation amplifier to drive the speaker, the
low-end frequency response of the audio is significantly improved. 9 The bass emitted
by the 10-inch speaker is extremely elastic, while the bass emitted by the 6.5-inch speaker is also more impactful. The feeling of impact coming
- Detection of Bidirectional Trigger Diode
- Make a Economical and Practical Rectifier Voltmeter
- Simple and practical motor short circuit tester
- NE555 makes a simple and practical acupoint detector
- Design of Multi-point Temperature Measurement System Based on DS18B20
- AC ammeter circuit
- Fluorescent tube inverter circuit and emergency lighting circuit 02
- Geiger counter circuit diagram
- Light Detection 4 to 20mA Current Transmitter Circuit
- Three-phase three-wire active energy meter connected to three ammeters
- AP500 and its application circuit (d)
- Simple 100W power amplifier circuit
- Bridge push-pull amplifier circuit
- Linear feedback-free power amplifier circuit (b)
- Pure Class A DC power amplifier circuit
- Class A and B DC power amplifier circuit
- New Class A power amplifier circuit@has been issued - voice phone
- High fidelity TDA1520 integrated power amplifier circuit
- Class A power amplifier circuit with dynamic bias
- DC field effect power amplifier circuit using AP500A
