Class A and B DC power amplifier circuit
Source: InternetPublisher:睡不醒的小壮 Keywords: Power amplifier circuit BSP interface Updated: 2020/03/25
The whole circuit consists of a dual differential input stage, voltage amplification stage, bias circuit and power output
circuit.
The input stage consists of an input interface and a dual differential fully complementary input circuit. There are three input interfaces: Interface 1-2 is suitable for
connecting with a preamplifier with balanced output with volume control. Interface
2-3 is suitable for
connecting with a preamplifier with unbalanced output without volume control . VTi ~ VT4 form a differential input circuit, RPl and RPz are balance adjustment potentiometers.
VTs~VT8 form a dual differential complementary voltage amplifier stage.
VT17 and VI)l are used to form the output stage bias circuit, and VI is a temperature compensation diode. The output impedance conversion stage is composed of VTg and vTio
, and an emitter output device is used to improve its load capacity
. Ⅵ¨~VT16 form three pairs of parallel complementary push-pull power output stages, and the quiescent current of each tube is adjusted to 380rnA.
Ma and Ra form a negative feedback loop. The closed-loop gain of the whole machine is determined by Rg/R8. About 31dBocz and C4 are phase compensation
capacitors to eliminate self-excitation.
- Share a mini piano circuit
- Tutorial on making a MIDI arpeggio synthesizer
- Make a high-quality DAC board
- Making a Simple Tube FM Radio
- 6N5P tube direct-coupled single-ended amplifier
- The production of 6P14 small tube amplifier
- Installation of electron tube differential amplifier circuit
- Typical applications of optocouplers in audio amplifier circuits
- Bridge output audio power amplifier circuit composed of LM1876
- Dual power supply audio power amplifier circuit composed of LM4730/LM4731
- Motor overcurrent protection circuit
- Electronic thermometer circuit
- Ultrasonic blind pathfinder circuit
- Electronic anti-asthma circuit
- Rural vegetable greenhouse lighting circuit
- DC ammeter
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Inductive feedback oscillator circuit
- Power phase sequence display circuit
- Motorcycle flash light circuit
