Bridge push-pull amplifier circuit
Source: InternetPublisher:武林萌主 Keywords: Push-pull amplifier power amplifier circuit BSP Updated: 2021/09/13
It is a bridge push-pull low-frequency power amplifier circuit with a very simple structure and an output power of up to 1W.
It can be used as an external power amplifier for a walkman, or as a power amplifier for telephones, intercom doorbells, alarms, etc. o VTI and VT2 form a differential input stage, and the signal
amplified by the differential input stage directly drives the output
stage of the bridge push-pull amplifier. . Since there is no intermediate amplification stage, the differential input stage also serves as a phase splitter. After the input signal is amplified by the differential input stage
, it is divided into two signals of equal size and opposite phase, which are output from the collectors of VTi and VT2 respectively.
VT3~VT6 form a bridge push-pull power output stage, which amplifies the signal amplified by the differential input stage and then pushes
the speaker o
- How to adjust the bass and treble of CXA1005
- Simple and practical small amplifier
- Practical and high-performance preamplifier circuit
- Experiment of 2-in-1 single-ended Class A tube amplifier
- Preamplifier made of 6P15 tube
- The production of 6P14 small tube amplifier
- 6AS7 tube amplifier
- Volume synchronization circuit constructed with discrete components
- LM4903/4905 differential input audio amplifier circuit
- LM4819 high gain audio amplifier circuit
- Electronic thermometer circuit
- Pulse therapy circuit
- Crop anti-frost circuit
- Rural vegetable greenhouse lighting circuit
- Farmland irrigation automatic control circuit a
- Diode square rate detection circuit
- Inductive feedback oscillator circuit
- Voltage controlled power supply second-order high-pass filter circuit
- color discrimination circuit
- Power phase sequence display circuit
