Simple pre-frequency crossover amplifier
Source: InternetPublisher:天天都吃好吃的 Keywords: Amplifier BSP audio balance control Updated: 2020/09/08
Reproducing high-quality sound through simple circuits is a goal that many audio enthusiasts pursue tirelessly. This circuit is based on
this point. It uses a simple circuit to reproduce beautiful music and is suitable for audio enthusiasts.
This circuit is designed using a dedicated integrated circuit TA7630P for stereo sound, volume and balance control . This integrated circuit realizes volume, tone and balance control
by changing the DC voltage on its ⑦, ⑧, ⑨ and ⑩ pins , avoiding the mixing of
noise and improving the signal-to-noise ratio of the circuit. The potentiometer leads can be easily It is long and has a casual layout, which reduces the difficulty of production.
The schematic diagram of the corona circuit is shown in Figure 5-123.
In order to save the more expensive I. C frequency divider and to obtain more pure sound quality, this circuit uses rkc passive two-way frequency network
, which can not only obtain flat amplitude characteristics and phase characteristics, but also make the circuit production extremely easy. This circuit is composed of resistive components
to form a passive two-division frequency network. According to the values in the figure, the frequency division points are. Factory 1 l/2丶RC≈l60/RC≈3, 4kHz.
- Balcony intelligent invisible anti-theft net
- Analysis of valid and fault conditions of differential signals
- Multi-speed current test circuit of transistor HFE
- LM3914 makes car battery detector
- Design of Multi-point Temperature Measurement System Based on DS18B20
- Production of acoustic and optical digital level detector
- Application of TDA1514
- AC ammeter circuit
- DS8 type 100V, 5A mutual inductance three-phase three-wire electric meter wiring
- A simple no-load self-stop circuit for welding machines
- Pulse therapy circuit
- Electronic anti-asthma circuit
- soil content measurement circuit
- Domestic KD8041 integrated phase locked loop
- Double detuned loop frequency discriminator circuit
- Frequency modulator composed of NE566
- Varactor Diode Frequency Modulator
- Capacitive feedback oscillator circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Voltage-controlled voltage source second-order band-pass filter circuit
