The production of "Walkman" power connector 02
Source: InternetPublisher:ghaytweyhtoo Keywords: Radiator BSP two-channel TDA1521 Updated: 2020/12/07
When TDA15 21 is working, a heat sink plate with an area of 120mm×50mm needs to be added. In amateur conditions,
scraps of aluminum-plated gold doors and windows can be used. Since the ⑤ pin of TDA1521 is connected to its own radiator and has been connected to a negative voltage, be careful not to
short-circuit the radiator to the same ground during production. b. It is best to apply a layer of thermally conductive silicone grease on the contact surface between TDA1521
and the radiator.
If greater power output is required
As shown in Figure 5-89, the power
amplifier circuit 6 made
of
TDA1514 "Southern Whale" YD1768X (8, Q,
80W) YDQG20--8F (8fl, 30W) speakers were tried
. The sound was transparent and pure, and the bass was full and thick
. The treble is clear and bright, and has
the charm of a tube amplifier. When the power supply voltage is ±25V, Ri. -
8fl, the output power can reach 50w, which is enough to meet
the needs of home listening. Since the two-channel circuit is the
same, only one circuit is drawn in Figure 5-90. The printed circuit board has been designed as a two-channel structure and shares a set of power supplies. When TDA1514A is working,
a heat sink with a large enough area is still required to ensure long-term operation. It is advisable not to be hot to use. The @ pin of the TDA1514A
is connected to the radiator itself. During use, be careful not to ground the radiator . Since two TDA1514As work at the same time, if you
want to listen to music at high power for a long time, a toroidal transformer of about 200W will be better.
- Make a Simple Darkness Detector Circuit
- Convenient and fast power line break detection circuit
- Electromagnetic radiation monitor
- Homemade refrigerator monitor
- Using NE555 to make diode and triode detector
- LM3914 makes car battery detector
- Homemade Metal Detector
- Digitally controlled operational amplifier gain circuit
- Fluorescent tube inverter circuit and emergency lighting circuit 02
- Numerical control following or inverting circuit
- strain sensor
- Self-defense anti-riot circuit
- Rural fish farming control circuit
- Soil water shortage prompt circuit
- AC voltmeter
- Mixer built with analog multipliers
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- OTL low frequency power amplifier circuit
- High and low frequency signal generator circuit
- Power phase sequence display circuit
