High quality stereo HI-FI combo amplifier 05
Source: InternetPublisher:子丑寅卯 Keywords: amplifier stereo HI-FI BSP Updated: 2020/09/12
(5) TDA1514A×2 power amplifier
In order to obtain greater power and have sufficient power reserve, you can use
the 50W high-performance single-chip power amplifier TDA1514A specially launched by Philips for digital audio. Its low-frequency power is excellent, the treble is slender, and the mid-range power amplifier is The sound is full, and it is effortless to play large-scale symphony music
. The i-5U
performs well on strings and has excellent positioning. After trying it, you will find that TDAls14A is indeed well-deserved, and
its performance is worthy of the cost of 10 yuan. When using TDA1514A in mono or dual channel, two pieces are needed. The limit
voltage of TDA1514A is ±30V, and ±2sv is often used to work, so it is self-contained. When using a transformer, please note that the secondary buffer voltage of the transformer should not exceed ±18V, and
the power should be about lzOw.
- New function added to MF-47D multimeter - infrared remote control detection
- Electromagnetic radiation monitor
- Level measurement circuit composed of AD737
- TC02 temperature measurement circuit
- LM3914 makes car battery detector
- How to create a simple oscilloscope using the Basys3 board
- Electric vehicle luminous voltmeter with undervoltage alarm
- Light Detection 4 to 20mA Current Transmitter Circuit
- High Performance Digitally Controlled Amplifier-Gain Divider
- High resistance DC differential amplifier circuit
- electromagnetic field sensor
- Agricultural temperature control circuit
- Crop anti-frost circuit
- Straw returning to field crusher circuit
- Double detuned loop frequency discriminator circuit
- Voltage series negative feedback amplifier circuit
- common emitter amplifier circuit
- Power phase sequence display circuit
- Fault signal trip circuit
- Various signal generator circuits
