High quality stereo HI-FI combo amplifier 01
Source: InternetPublisher:常思一二 Keywords: amplifier stereo HI-FI BSP Updated: 2021/02/09
(1) The following pictures of the head amplifier
are all two-channel three-dimensional structures, and only one of the channels is shown. The reason why NE5532 has the reputation of the king of op amps
. Thanks to its low noise and high slew rate. Considering that many audiophiles who are new to the audio industry still use tapes as signal sources. More
importantly, tapes are rich in content, updated quickly, and are cheap. Therefore, it makes sense to make a head amplifier. The head amplifier made of NE5532 is the same
as that of ordinary radio cassette players. (Compared with the A3161.TA7668 head amplifier, you can find
the excellence of NEsS32. After replacing the ordinary head amplifier alone, you can find that the amplifier is quiet when there is no signal. When the sound sounds,
it is like throwing a ball into a calm pond. A few stones can greatly improve the clarity of speech and music; the bass is rich and thick, the treble is slender and pleasant
, and has the effect of high-end sound. The detailed circuit is shown in Figure 5-77. In addition, it is best to pay attention when using this head amplifier. You can replace
it with a dual-contour, wide-response DM62 magnetic head, and the effect will be more
obvious. It has music details that ordinary magnetic heads cannot distinguish. 6
When making, pay attention to the shielded wire between the magnetic head and the amplifier
, and it should be as short as possible and enough. Just use it.
It is best to shield the prepared head amplifier with an aluminum box to prevent interference. 9 If you make your own circuit board, be sure to
separate
the input and output signal lines. 6
- Multimeter with small capacitor test circuit
- Convenient and fast power line break detection circuit
- Analysis of valid and fault conditions of differential signals
- Simple infrared detector
- Multi-speed current test circuit of transistor HFE
- Temperature-frequency conversion circuit composed of CD4046
- How to Use a Radio as a Metal Detector
- 1.5V and 9V battery tester circuit diagram
- An electronic load meter using LM324 operational amplifier as the main control device
- Numerical control following or inverting circuit
- Self-defense anti-riot circuit
- stuttering correction circuit
- Agricultural small tractor lighting circuit
- Greenhouse temperature control circuit
- Poultry warming temperature control circuit
- Diode Balanced Mixer Circuit
- Simple AGC circuit in transistor radio
- Series crystal oscillator
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Small current generator circuit
