Homemade fully integrated circuit amplifier 01
Source: InternetPublisher:aerobotics Keywords: Amplifier integrated circuit audio channel operational amplifier Updated: 2021/08/26
The circuit principle is shown in Figure 5-60. 6 A set of operational amplifiers of the operational amplifier integrated circuit form a channel preamplifier to
compensate for the loss caused by the insertion of the tone control circuit. Another set of operational amplifiers forms a channel push stage amplifier circuit to
obtain sufficient excitation voltage port RP11. RP4 and other components form a two-channel bass adjustment circuit; RP2, RP3 and other components form
a two-channel treble adjustment circuit. The two-channel volume control circuit is an equal loudness control circuit, which
is composed of RP5, RP6 and other components. At lower volumes, the bass can be boosted accordingly. Adjust RP7'_RP8 to balance the left and right channel volume output. The power
amplifier circuit uses TDA2030 integrated circuit , which has a V-shaped five-pin single-in-line plastic package and is small in size. When using
a ±18V power supply, an output power of not less than isw can be obtained on an 8.0 load and a distortion of less than 0.5%. As shown in Figure 5-61,
it is l. The appearance of M324 and Tf)A2030.
- Simple and easy to make zero degree detector
- DIY Multimeter High Frequency Signal Probe
- Multi-speed current test circuit of transistor HFE
- An electronic load meter using LM324 operational amplifier as the main control device
- AC ammeter circuit
- High current, high power amplifier circuit
- voltage amplifier circuit
- Multimeter DC voltage measurement circuit
- Differential amplifier circuit
- Bus door status detection circuit
- Three-phase AC power supply phase sequence detection circuit
- Left channel simplified circuit
- Dynamic noise reduction circuit for left and right channel separation
- Application circuit of LM1035 and 36
- Long-distance ringtone detection circuit using photoelectric coupler
- Detect the major point waveforms of the circuit
- Simple phase detection circuit
- Static electricity detection circuit composed of LM324
