Bus door status detection circuit
Source: InternetPublisher:萌面大虾 Keywords: Status detection detection circuit Hall sensor Updated: 2020/03/20
Shown is a bus door status detection circuit, which is mainly composed of three Hall sensors
and is suitable for
indicating the door status in various cars.
Three Hall sensors are installed on the door frame of the bus door, and magnets are installed at appropriate positions on the door. When the door is open
, the magnet is farther away from the Hall sensor, causing its output end to output a high level. If any one of the three Hall sensors detects that the door is not closed
or locked, the NOR gate outputs low level and the red indicator light turns on; if all three sensors output high level, the NAND gate outputs high level and green The indicator
light is on, showing the current status of the door in real time.
- How are diodes made using semiconductors?
- What does a rectifier do? What is the process of rectification?
- Principle set of zero-crossing detection circuit advantages and disadvantages
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- FPGA Features and Architecture
- How to build a drag racing timer circuit using a 7-segment display and discrete components
- Important things to know about PCB routing and how to design the right routing for your PCB
- LED Night Light
- FL52C4 induction electronic greeter
- Capacitive proximity sensing detection circuit
- Printing machine photoelectric paper break detection circuit
- Woodworking hand planer safety device detection circuit
- Simple infrared detection circuit
- Static electricity detection circuit composed of LM324
- A5348 smoke alarm detection circuit - block diagram
- Long wave infrared detection circuit
- Telephone ringing detection circuit
- ADM690~ADM695 constitute a detection circuit (2)
- Ray detection circuit
