Integrated circuit BTL amplifier 01
Source: InternetPublisher:柯南道尔 Keywords: integrated circuit power amplifier mono Updated: 2021/09/22
The key to reducing open-loop distortion in a power amplifier circuit is that both the circuit form and working state must be symmetrically balanced. Integrated circuits
form BTI power amplifiers to make the output circuit more symmetrical. As shown in Figure 5-49, the BTL emergency circuit port outputs a positive half-cycle current
b flowing through Vl, RI, and V4; a negative half-cycle current b flowing through V3, RL, and V2. The ideal situation is that the current b flows through V3, RL, and V2 in each cycle. R and b of RI
are equal in value and opposite in direction. A symmetrical and complete sine waveform is synthesized on RI. The condition is:一&, &
=and, or pl=口. , &= wind, the circuit can obtain the symmetrical output of la -Ib. As we all know, the final stage of many audio integrated power discharge
circuits uses a quasi-complementary single-ended push-pull circuit. The two same-polarity tubes at the final stage of this circuit are not in the same working
configuration (common emitter and common collector hybrid). Although the tubes The parameters are very close to the same, but the working status of the upper and lower arms is asymmetric, so
the open-loop distortion is very large. Its high index output is obtained by deep negative feedback, which also contains potentially large transient intermodulation distortion
. If it is formed into a BTL circuit, this asymmetric state can be greatly improved. Especially two-channel integrated circuits
(such as STK465, etc.) inherently have 8, 1, &= and good symmetry. After forming a BTL circuit, it is easy to obtain
saddle-low open-loop distortion, and its output is high. The indicator is the real good indicator, and the sound quality can be significantly improved. For mono
integrated circuits, due to the better consistency of the tube parameters in the integrated circuit , when two mono circuits form
a BTL circuit, It is also easier to satisfy B. =p:,p. =p4 symmetry condition, and obtain lower open-loop distortion.
- Electromagnetic radiation monitor
- 4040 Mobile Phone Electromagnetic Radiation Demonstration Experiment Circuit
- Detection of Bidirectional Trigger Diode
- DIY Multimeter High Frequency Signal Probe
- Digital electronic thermometer using semiconductor diode as temperature sensor
- Analysis of valid and fault conditions of differential signals
- Production of acoustic and optical digital level detector
- AC ammeter circuit
- DC power meter
- Typical two-stage low-pass filter circuit
- Capacitors in OCL amplifiers
- 80Wx2 high-fidelity power amplifier
- 50Wx2 Hi-Fi amplifier
- LM3886 BTL amplifier
- Use LM3876T to connect to BTL power amplifier
- Power amplifier composed of LM2876
- XA8500 power amplifier
- Fever Sanbanax HI-FI
- Upper and lower symmetrical negative feedback mode field effect transistor power amplifier 02
- High-fidelity power amplifier using switching power supply 02
