Use LM3876T to connect to BTL power amplifier
Source: InternetPublisher:奥特man123 Keywords: Amplifier BSP Updated: 2020/04/23
If you need to increase the power reserve of the amplifier, you can use two pieces of IC to connect to form a BTL circuit. Figure 2-58 shows a BTL power amplifier circuit using two
pieces of LM3876T to connect . If this circuit uses dual AC 27V power supply, it can output
120W power on an 8n load . In order to adapt to a variety of sound sources, NE5532 or LM833 can be used as a lOicU3 preamplifier.
Tests show that when LM3876T is used as BTL output, the performance is quite good, while when LM 3875T is used as BTL output, the performance
is slightly worse.
- 6P3P parallel 20W power amplifier experiment
- The easy production of several top-quality tube preamplifiers
- Practical and high-performance preamplifier circuit
- Production of 6n3 Pushing 6p1 Single-ended Tube Amplifier
- Making a Simple Tube FM Radio
- Using an old tube radio to make a 6N1+6P14 tube amplifier
- A very simple amplifier
- High gain audio amplifier circuit composed of LM4818
- LMl876 is used to assist the audio power amplifier circuit
- Stereo amplifier circuit with Av=200 (gain) composed of LM1877
- Motor overcurrent protection circuit
- Electronic thermometer circuit
- Electronic anti-asthma circuit
- Mixer built with analog multipliers
- Simple AGC circuit in transistor radio
- Diode balanced amplitude modulation circuit
- Series crystal oscillator
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Small current generator circuit
- Sine wave signal generator circuit
