Tube power amplifier driven by NE553201
Source: InternetPublisher:MartinFowler Keywords: Tube power amplifier NE5532 BSP Updated: 2020/05/12
The power amplifier circuit of this machine is shown in Figure 2-16, and the power circuit is shown in Figure 2-17. The circuit principle will not be described in detail. The filament
6.3V voltage is obtained after being stabilized by LM317T, and can also be connected as shown in Figure 2-18 The constant current source circuit shown
is beneficial to extending the life of the filament, but debugging is a little troublesome. R is about 1.5fl. When making the coupling capacitor, be sure to use high-quality CBB capacitors
or tantalum electrolytic capacitors. The resistors , except those indicating the power, use 0.25W metal film resistors D.
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- Causes and solutions for noise in digital Class D amplifiers
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- DIY a decorative lamp
- Analysis of three simple electronic dice circuits
- Make a flameless electronic candle using simple electronics and LEDs
- How to build a triangle wave generator using an op amp and discrete components
- Structural diagram and function of sliding resistor
- What is the difference between high-side and low-side resistive current sensing
- Star finder battery indicator circuit
- Set timing circuit when power is on
- Agricultural temperature control circuit
- Chicken supplementary light to increase egg production rate circuit
- DC ammeter
- Junction field effect transistor mixer circuit
- Capacitive feedback oscillator circuit
- Broadband high frequency power amplifier circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- High and low frequency signal generator circuit
- Fault signal trip circuit
