Low-cost and efficient home inverter circuit schematic
Source: InternetPublisher:他们逼我做卧底 Keywords: Circuit schematic diagram inverter circuit transistor multivibrator Updated: 2020/05/12
The picture shows the schematic diagram of a low-cost and efficient household inverter circuit . After the 12V power supply is turned on, the multivibrator composed of transistors VT1 and VT2, resistors R1 ~ R4, and capacitors C1 and C2 is powered on and starts to oscillate. VT1 and VT2 work in turn. The collectors of the two tubes output a square wave close to 50 Hz. The integral circuit composed of C3 and R5, C4 and R6 is integrally shaped into a quasi-sine wave, which is then inverted and amplified by VT3 and VT4 and then respectively stimulates VT5 and VT6 to make the power amplifier tubes VT7 and VT8 work.
- A very convenient small power supply circuit to share
- In-depth analysis of DC-AC converter inverter
- Fabrication of multi-cell lithium battery charging circuit
- Step-down power supply for driving relays
- Driving circuit that controls LED brightness using PWM signal
- A small and easy-to-make fast charger
- Adjustable regulated power supply with current limiting protection
- Adjustable voltage power socket
- Practical constant current charger-----Constant current charger
- Homemade Electric Bike Fast Charger
- 3V-5V level conversion circuit diagram
- Simple transistor relay delay pull-in circuit diagram
- White noise electronic lullaby circuit diagram
- Single supply complementary symmetrical circuit
- Color changing flash light principle circuit diagram
- Discharge time relay circuit
- Transistor reference basic bias circuit-hybrid negative feedback type
- Stabilized power supply circuit adjusted from zero
- Precision regulated power supply circuit for UJ-1 type potentiometer
- One of the water full alarm circuits
