Simple AC/DC indicator circuit diagram
Source: InternetPublisher:containsmachine Keywords: Circuit diagram AC/DC LED DC Updated: 2021/06/14
Presented in this page is a very nice and simple AC/ DC indicator circuit diagram . The AC/DC indicator light circuit diagram is based on two transistors one PNP and one NPN transistor. This circuit will use two LEDs to provide a visual indication. Also this indication circuit AC/DC will provide a message if the test signal is positive or negative. The red LED will glow if the signal is positive DC and the yellow LED will glow if the test signal is negative when the signal under test is AC Two LEDs will glow (LED1 and LED 2) and the tester will need a dual 9 volt power supply circuit . Do not use high voltage AC or DC signals.
- Sharing layout and tips for multi-rail power supply design
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Visible laser digital control modulation driver
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Car power 1.5V-12V six-speed converter
- MIC4680 constant current charger
- A low-cost, high-reliability battery charger for electric vehicles
- Remote control circuit a composed of TDC1808
- High performance DC power amplifier drive circuit AP500A-02
- DC field effect amplifier 01 using AP500A
- Modified voltage stabilized power supply diagram
- Rongsheng DCX-63A dual temperature electronic disinfection cabinet circuit diagram
- Transformer coupled DC and DC converter circuit diagram using HS7076
- Step-down DC and DC converter circuit diagram using HS7076
- Multi-output DC and DC converter circuit diagram composed of L4970A
- AC and DC adapter circuit diagram designed using L4990
- 3V-12V DC DC conversion circuit 2
